Well, I am planning on using megasquirt. I already ordered my kit and have it somewhat assembled. I will be using it for fuel only at first. Once I get it working I plan on adding ignition, though I dont know what kind of modifications are going to be necessary to get it working. Hopefully I will be running smoothly long before I add the turbo, as I'm sure thats going to add some complexity. I could always buy an MSD 6A to control timing via interfacing with megasquirt.
I was wondering about adjusting the fuel pressure to get more fuel, but I dont know if that will provide enough fuel for my goals. I will probably buy some 24# or 28# injectors and keep fuel pressure stock, though I'm open to suggestions.
I plan on adding a BOV value just because its another safety mechanism, and if i'm going to spend the timing doing this, im going to do it right.
I'm also curious as to what kind of power the stock fuel can hold up to, which I hope is alot because I dont feel like buying a new one
For the turbo, right now I have my eyes set on a garret hybrid t04e .57 trim .63 A/R. I see holsets for cheap, but I can never find flow maps for them. I emailed the company but never recieved a response. It seems the holset HX-35 might be a reasonable choice, but the only thing I have to base that on is the opinions of others more familar with turbos.
I will definitaly try to intercool, but I have even less of an idea of what to do for this than the rest of the system. I dont want to mount one in front of the radiator since it needs all the air it can get. If you have ideas let me know. It would definitely be of benefit to both of us if you were also doing this project, as we could help each other.
And thanks for putting the pics up mtbkr, I have them saved on my computer now to use them for ideas. Since, you've done this already, I'm sure you could throw some helpful advice out as what to avoid,etc, if you don't mind that is.
As far as mounting the turbo, I'm not really sure. My plan for now is to mount it at the collector and put some braces from the frame to support it. I still have the stock header, and with its log design, i'm wondering how much that will hurt performance. I know in stock applications a header doesn't do much but this is not a stock application. I would hate spending 300-400 dollars on a nice header if it worth it.
