tealcherokee
- CT
yeah, its about 60-70lb injectors, which will actually idle at 14:1 afr @31psi
the problem w/ a progressive fpr (rising rate, FMU, all the same garbage) is say you run larger injectors, 40lb@49 psi. the MAX pressure those injectors should ever see is 49 + 10%, so ~54psi. and youre running a small FMU (2:1, where theyre avail up to 12:1). so now you have 49psi at 0 boost, and 15 lbs of boost. so thats 30 psi added to your fuel pressure, now you have 79psi at the rail and injectors. even if you spend the 100's on stainless lines and -an fittings, its still WAY too much pressure for the injectors.
and the stupid honda ricers running 12:1 fmu's and 90000000 psi fuel pumps are literally pressurizing their fuel system to close to 300 psi, ive seen set ups, 12:1 fmu's 20 psi of boost. and ive seen ALOT of car fire pics because of fuel leaks.
run an EMS (programable computer) or dont boost it
