I installed the Detours and like them for both the frame stiffing and the rock rails. I then stalled the TNT underbely skid/armor (modified it to bolt not only to the uniframe, but also to the stiffner. My stiffner and skid now form an "H" under the body which is then tied to the front (LCA) and rear spring bolts. Now that's a frame.
Rigid front bumper with steering box extension coupled with C-rok and most the unibody is stiffened.
I was under the assumption that the t&t stiffeners wrapped all the way around like channel, however after some searching i found thats not the case. How far do they go? All the way across the bottom, or do they make it up the inside of the frame rail any? I should have a cage here sometime this week and i figured why not use this to help things and to tie it into. Even though its more or less angle, it should still be more then sufficient for this right?
