Gary Briggs
- Escalon, Ca
That 12* angle is not desireable, avoid that if you can.
I'm not a fan of it either... but it keeps following me around.. not cool at all.That 12* angle is not desireable, avoid that if you can.
HahahaI'm not a fan of it either... but it keeps following me around.. not cool at all.
HD Offroad no lift relocation brackets and JKS shackles.
Id just run Jks and be done
One thing I was told is that people over tighten the rear shackle bolts so they dont pivot.. Mine are just tight enough to allow them move with rear spring flex and unload.
How do your leafs sit? Are they very arched? Mine seem to be a bit more on the flat side than the arched side. It's a hard angle to photograph. But I will tryBeen following this thread since I had ordered the same springs. Rear came up 2" and the front with new factory spring insulator gave me 1 1/2". Have some Terraflex 3/4" spacers that I'll throw on and probably some JKS boomerangs in the back.
Thanks for that advice Ron, I'll take it.
Know the torq spec off the top of your head by chance?
