bacelaw
- boston, ma
DenLip said:It's a matter of opinion.
And, again, investing many hundreds of dollars, and/or many hours of time, to do the "right" fix on a ten-year-old car simply isn't worth it to many folks.
Den
100% in agreement...to do it "right" would prob. require a new complete floor pan from a southern jeep, welded in as it was in the factory....THAT would take more like a thousand dollars, and tons of work your average do-it-yourselfer is not prepared to do.
However, after researching, i found that there is a happy medium between a "right way" restoration, and a complete half-ass job....This middle ground is the route i'm taking...
As far as expense, rust management isn't pricey - just very labor intensive...sheet metal is cheap, screws are cheap, spray cans are cheap, roofing tar, the only real expense is the herculiner and undercoat...all told my fix will go nearly $200.00....and definately hold off the rust for five years...then, maybe ill address it again.
or, sell the 250k mi jeep to someone to run into the ground...
