Not to be rude here, but you kind of TOTALLY missed the ENTIRE point of my original post... I was asking about a way to adapt my compressor to my bracket with the alternator relocation brackets (YJ and ZJ) to keep both is "stock" locations, NOT get rid of AC to move an alternator...
The bolt pattern is completely different, the HO ac compressors and the compatible YJ brackets all used the Sanden 708 pattern which bolts top down, the Renix, which is Sanden 508 (better, though older compressor) bolts front to back. Bolt sizes are obviously different as well. What I will end up doing (STILL haven't done this yet) is redrilling an adapter plate I bought online. Found a plate to adapt a Sanden 508 to a York mount, will weld up the plate holes, mount the bracket to the compressor and position it inline with a belt for proper alignment, then mark and re-drill the plate holes to the bracket spacing so I can just bolt it down in place. The biggest PITA part of this project was finding the hoses, finally found them and FINALLY found the correct drier for this thing (ordered a couple days ago) so will have everything I need to get back to work on this when it thaws out here a bit...
I am pretty sure, at least from what I remember from when I did the research to do this, the ZJ upper bracket was larger and that its compressor spacing was as well... The lower bracket IS still desired though for others doing this as it adds the 2 through bolts through the front AS WELL AS 2 bolts to the engine itself for a MUCH stronger mount. All my researched everything for this project was on a laptop HD that crashed shortly after I got a bunch of engine work done or I could double check the measurements for you lol.
Again, I REALLY don't mean to come off the wrong way on this here, but can you please start another thread for that one? My thread was about something COMPLETELY different... Thanks.
