For the most part, I can say the front is done for the time being. There will be tweaks and corrections that I will post later. But for the sake of everyone reading this thread (and gripping their seats in anticipation) .... I will continue ahead.
One of the great things about the traditional hub/lockout assemblies is the ability to "unlock" and drive home if you destroy a front shaft. Because the spindle is supporting the vehicle weight (rather than the unit bearing & front outter stub) .... it is much quicker & easier to remove broken parts.
But a nagging thought kept coming to me. What about the rear? I've only seen a few rear shafts let go in that capacity. Busted C clips are one example of a potential failure. Twisted splines are another. I do agree, that outright breakage isn't a common issue.
Whatever the case may be ... a busted rear shaft can stop things in a hurry because the shaft is transmitting rotational torque *and* holding up the vehicle. So what to do?
I liked the idea of the full floating setups seen on fullsize pickups. Like the front, the hub rides on its own spindle. Therefore, all the axleshaft does is transmit torque for forward (or rearward) motion. Only 2 caveats. 1) Didn't want full width 2) Didn't want 8 lug
Anyone that's visited me (I don't have many friends
) knows I have a collection of parts at any given time. Saw one of my D60 housings sitting on the floor unused and the thought process started. " How about cutting off the spindles and making a full floating D44 setup " was the idea I had. Before anyone jumps all over me .... I already have a D44 ARB that I wished to reuse. The units are expensive and I do not see much strength gain from going to a D60 with my "little" 33 inch tires.
My XJ already had a factory 44 in place; however, it was not the best candidate for a full floating setup. I did not want to use the bolt on kits available (similar to the old Warn FF kit). That mean using real spindles & hubs. Going this route meant that I would have to account for axle width when putting this assembly together. As I researched ... I came to find out the GM 14 bolt has a slightly smaller hub body. Why is that important? I did not want to change to an 8 lug bolt pattern. That smaller body diameter makes it easier to retain the 5 lug pattern I already installed up front. No problem. Not to mention I already had a dead GM14 bolt here I could work with.
I located a full width D44 from an F100 pickup truck. Based on measurements ... I needed more tube length so that I could cut away the flared ends (for the the semi floating shafts) and attach the spindles.
Let me tell you ... driving 2+ hours with a 37 year old axle in your wife's 2 year old car takes balls. :shocked:
