I am starting a new build up and need some input. I need info on axles front and rear what would you guys run if you could? I was thinking 9" or 14bolt or maybe D60 what would be the best and found at a salvage also what vehicles did they come in. (Father in law owns a salvage), I am looking at about 4.5" of lift and at least 36" tires maybe bigger. There won't hardly be a fender and I am removing all doors and maybe lengthing the wheel base. Let me know your ideas. so far the plan is to use a I6 HO with 231 or Dana 300 tcase. Full spool rear with locker in front.
