It's been awhile since I've updated this so here you go! Since I'll be driving this at nacfest it NEEDS to be done in 3 weeks. which I think will happen now....
Finally no more bending up floor pieces
Also took care of the rot right here as well and cut the rear support. I'll cut the bumper to match the same 45*
Next I tackled my trac bar bracket, since I'm running a Ballistic 2.63 joint there was no way that would fit in my stock RE bracket so I modified it. I feel pretty confident about it not going anywhere, wrapped some .250 plate around and then braced the side of it as well.
It's still a tight fit but nothing should hit.
Now I know I should of moved the mounting hole up, but how do my angles look?
I started putting my front clip back together for the final time as well. the 3/8 bolt might not look the best but it's the easiest solution to tie the bottom of the fender to the boat-side.
And with the tire on for the general idea of where it's going to sit.
It's so nice to see this side finally come together somewhat as well!
May not look like much but this was a complete pain to re make. about an inch above the bends was gone, it all rotted out. It didn't come out bad really considering it was all done by cardboard templates. (Don't mind the door gap, no shims were in the hinges)
