Justpunchit
NAXJA Member #1291
- Jaffrey, NH
Jeep looks great.
Was looking at getting either the rusty's or ballistic spring mounts. You strong support of Ballistic's products has pushed to get them. Keep up the good work.
Subscribed.
Thanks! and I think there worth every penny over the Rusty's kits. I'm working out the kinks in my OTK kit tapping my coil captures at full lock but besides that I wouldn't of done it different.
Also while I was working up front I decided to run dual taurus fans so I took the pulley out and made a new belt routing and also took care of some gasket issues such as oil filter, valve cover, and oil pan. While I had the pan down I opted for a Mopar High volume oil pump, even though my engine does have semi low miles I just wanted to be safe than sorry.
Here you can see the new routing better along with my modified XJ rad house that takes a lot less run since there's no more ac in this rig anymore.
Also put in the time to finish weld the other side stiffeners to accept my boat sides. MAN is that alot of welding.
