cyl 2 and 5 are lean, 4 is what all of them should look like, 6 looks like slight buildup of soot or corrosion from either a small coolant leak or a small amount of blow-by, 1 and 3 are either showing rust from a bad head gasket or running rich.. it's hard to tell from the photos but it looks like a cylinder that is running rich but still firing. smell them and see if they smell more like fuel than the others.
also you are running 2 different heat range plugs that's a big no-no... see how the electrodes protrude further out of the insulator on 1 and 6?
1 possibly looks rusty on the threads, either your thermostat to heater hose pipe is leaking or was at some point.
diagnosis, do a compression check, a leakdown test, and a coolant system pressure test. I would also find a shop that can test your injectors for leakage or clogs, or just replace them.
hope this helps at least point you in the right direction. either way you are due for new plugs, replace all of them.
