NeXJ
- Los Angeles
Hi - Well I've read TONS of posts on the topic of passing the CA SMOG test and I've seen lots of ideas for solutions - and it seems to me that running aftermarket headers is a pretty great way to fail, since it seems to generate an excess of Nitrogen Oxides (NOx). Indeed - I just went for a smog and failed (only just - my situation isn't as bad as others) - but it's still a fail. Some clever member here remarked the coincidence between high NOx numbers and running headers.
SO - since I only have one more shot at this - and I don't want to pay someone off to pass me illegitimately - I'm in need of a solution. The last time I ran a bit (perhaps too little) ethyl alchohol in the tank (2-3 oz in a few gallons of premium).
HOWEVER I came across a few interesting posts about 1) disconnecting the t-stat sensor (also morally dubious - but hey) but also 2) disconnecting the battery RIGHT BEFORE the test so that the HO is running off computer fuel maps.
ANY SUGGESTIONS ON THIS? Can anyone guide me on this? Will killing the battery for ten minutes do it? How long does it need to run before running off of custom or 'learned' fuel maps again??
I have a 92 XJ with a 97 HO 4.0 with borla headers installed in 2000... high flow cat (magna? can't recall) etc etc. I think that's all the relevant tech info needed. Everything else is more or less in spec it seems. I'm not convinced a new O2 sensor is going to help much from what I've read.
ALSO- does anyone know if the fuel map trick is going to mess with my HCs and other numbers? I could kind of see that happening - even if it gets my NOs down...
