4LowandGo
- Kennesaw, Georgia
Any ideas on a pitman arm that might work?
If you are using a heim joint and bolt to attach the drag link to the pitman arm, then you can use a Dodge 2500 4x4 pitman arm. Since the taper is opposite of the Cherokee's you need to drill it out. The one I picked up from the JY bolted up to my Cherokee box and is longer than stock with more drop than the drop pitman arm I had before. My turning radius is back to normal now.
