SPXJ
- El Cajon, CA
I fabricated my own over the knuckle steering. The down side is I lost some turning radius.
:dunno:Any ideas for getting my turning radius back??
I thinking about trying a flat longer pitman arm..but there are issues there as well. I don't want to stress the steering box more than it already is. Any thoughts??
Here a write up of my steering fab….
I used 1 1/2 x 1/4 wall chromoly tubing.
Driver side bracket-
Passenger side bracket-
The brackets are attached at the original tie rod end hole
(drilled out to 5/8”), at the two forward wheel bearing bolts and an additional attach point on the out side of the bracket directly to the forward arm of the knuckle.
Here you can see the original tie rod location and the new location, driver side (forward and in).
Here you can see the original tie rod location and the new location, passenger side (forward and in).
The result of this was the tie rod is forward 1 ½” and 2+/- above its original location. I am very happy with the out come of this steering but I want my steering radius back!!!
