swbooking
- Riverside/Running Springs, Ca
Like I said, spend money once. Do it right do it once. Save your pennies.
X2!!! I say buy a good lift setup and get tires later if need be.
Also, we ALL like new things but if you can save 30-60% going used, I buy used. Its just gonna get scratched and dented anyway.
Why would you get the 4.5" SF and buy all the upgrades when you could just get the RE6200 5.5" and it comes with everything you need, no upgrades necessary? :dunno:x3. in the next few days i will be getting the RE4.5" SF will all the possible upgrades minus the long arms. i see it all as well worth it. most people lift and then keep upgrading until they finally get where they want. so why not skip the steps, and in the long run, save money
Sorry but I think this is what I'm going to go with. no more money left in the bank.
RE6130 $818.00
Rubicon Mfg Twintubes $155.00
HD Trackbar and Bracket upgrade $60.00
Adjustable upper & Lower Control arms upgrade $70.00
Shipping $65.00
Grand Total = $1,168.00
Then All i need to get is wheels and tires 32 x 12.5 x 15 Or should I just go with 33 x 11.50 x 15
And some black Soft 8's
Are going to regear at the same time? If not, prepare for the worst performing rig you've ever imaged.
At the low end of the price scale... lift, tires, armor, gears, LOCKERS... expect to pony up about five large. If you haven't got that kind of money, don't start lifting. Trust me.
BTW... the rules for 97+ are different than an older model. Older models are somewhat more forgiving. What year is your rig? Have you budgeted for new bumpstops? JKS Quicker Disconnects? Gas tank skid? Control arm skids? Transfer case skid? Diff guards? Fender trimming? Hi-lift jack, tow straps, recovery gear?
Once you start, it's a lot of money to finish. I don't want to scare you, but I do want you to be well informed on what all is needed just to put 33" tires on a Cherokee. The front coils and rear leaves are the easy part. It's everything else that you will need that most newbies don't think of or bother to factor in to their budget. Consider buying used parts to keep the costs down. Many people get their own case of inchitis and are selling their old lift parts. I've seen people piece together complete lifts and armor out of a pick-a-part junkyard. Get used tires and wheels until you get used to your rig or can afford to re-gear. Remember that unless you re-gear, bigger tires will cause your rig to drive like a dog.
BTW... why are you lifting your rig in the first place? Expedition exploring? Rock crawling? Camping & fishing? Different activities dictate what equipment you should have, how big your tires should be and that dictates how much lift you need.
When you start contemplating 33" tires, I truly believe you need to be prepared for an all or nothing process. Either do everything, or don't do anything.
I'm just saying.
Well... I hate to be the bearer of bad news, but anything larger than a 31 and you can kiss that D35 you've got goodbye, if you've got an 8.25 you can squeeze by on 33's... so you need to check. Good deals on rear axles can be had on here relatively often however, so keep an eye out for either an 8.25 or a D44.Thanks Jim, You are right on what I'm building. I'm wanting something for mild off-roading/adventure/camping. I'm not building a competition truck.
That said, is there a big difference in the 32" tire VS the 33" tire? As far as performance and ride and capability off road?
Best reason I've heard so far, don't let anybody talk you into going higher than you want, if you want a 4.5 go with the 4.5 and run 31's, they wheel great. Elias wheeled that for a long time, I chose to go higher after riding with some of the other guys etc. However, you WILL want drop brackets eventually.because i dont want to ever go higher than 4.5". 3.5" leafs + shackle will ride better than 4.5" leafs. and i get the SF ADJ CA's. so the only difference is ride height and the lack of drop brackets.
If you want to go with a 4.5" for sure, then buy the 4.5... But I'd go with 31's for now. That's an amazing combination FYI.So would a 4.5" lift on 32 x 10.5 give me better chances?
3.55's with 33's are a dog compared to 4.10's or 4.56's, yeah, it can get up to speed, but the acceleration sucks. Acceleration sucked with 31's and 3.55's, it can only be worse with 33's. Not saying it can't be done, but you put more stress on the transmission and transfercase without regearing for the tire, not to mention more load in the engine so you're mileage will decrease.
I'm just saying.
