Akira
- Washington
What are the improvements that the 8.8 has over the Dana 44?
Fixeded the grammar so it imakes sense, and CRAWL did a write up two months ago. But yes, the Super kit is cool...still it's a bunch of dough where an old-fashioned c-clip 8.8 is a pretty stout axle.mud1059 said:Neither JPFREEK or CRAWL magazine have covered it yet...
Did you watch the video I posted?Akira said:What are the improvements that the 8.8 has over the Dana 44?
Huh? :dunno:supsa said:Paul gots all the info . Your got you rig running?
I meant it more as an 8.8 testament, but thanks.Akira said:Yea I did watch your video! Freckin SICK and sounds GREAT! Looks like Im going with the Flowmaster 40!
Not a bad way to go, but I do think the 8.8 is a better long term value. Either way, it's a great step towards the trail rig you've got in your mind. Looking forward to seeing how it all turns out, and thanks for being recpetive to input.Akira said:But I'm thinking it just might be easier to get that dana 44 so that I can simply bolt it on... Yea know!
It was 3am. Gimme a break I appologize for being wrong about CRAWL. I didn't realize!IXNAYXJ said:Fixeded the grammar so it imakes sense, and CRAWL did a write up two months ago. But yes, the Super kit is cool...still it's a bunch of dough where an old-fashioned c-clip 8.8 is a pretty stout axle.
-----Matt-----
-----Matt-----
mud1059 said:Have you ever broken a shaft on a c-clip axle?
Megawatt said:Yeah Matt, you're not mentioning a major difference between the 8.8 and the 44. The dana axle is a semi-float design. No C-clips.
That doesn't mean a Ford 8.8 isn't a good swap. It's a good axle for NW wheeling. But keep in mind that a broken axle could be more of a problem with the 8.8.
I'm planning on adding discs to my 44. With the 33 spline alloys, the week spot is probably the pinion. Not good.
Avanteone said:Yes, of course the c-clip is a disadvantage, on paper. 1st: The 8.8 is disk brakes, a broken axle shaft in an 8.8 does NOT mean you're gonna get passed by your tire 2nd: I've YET to see an 8.8 break at the clip. I've seen a couple break the shafts further out (and they were V8's, big tires, etc). AND the Superior Super8.8 kit eliminates the C-clips and adds alloys shafts for not much more $$$ than alloy shafts by themselves.
J
mud1059 said:8.8 ~$400
Pros: Easily found, disc brakes
Cons: 4.88 cap, ground clearance, not direct swap, $500+ Superior kit can fix last two issues AND comes with sexy alloy shafts: not same width and C-clip axles.
There you have it.
Like I said, I was going off memory. Is it the D30 that has the 4.88 cap?Avanteone said:You can go deeper than 4.88 in the 8.8, I'm running 5.13's. The superior kit is not NECESSARY to be plenty strong. And, once you to the Super 8.8 kit you end up back out close to stock width... actually slightly wider. Also, if you're gonna try and compare apples to apples, throw in the $400 TERA disk brake upgrade for the D44.... or take away the $400 for the 8.8 disk brake axle and figure $50 for the cost of a drum brake unit.
J
IXNAYXJ said:Yeah, I remember trying to rock your rig out of the snow...not fun. You've also got the Wrangler transmission and I kept missing reverse; apparently it's a little different than an AX-15.
-----Matt-----
I did mention it, but having run an c-clip 8.25 for a couple years and now a c-clip 8.8 for a while, it's just not too big of a concern to me. Certainly I'll agree that semi-float is the better way to go, but there are other considerations I place more value on.IXNAYXJ said:...where an old-fashioned c-clip 8.8 is a pretty stout axle.
