NW99XJ
- Gresham, Or.
Hey guys, so here's where I'm at with things.....
1-ton OTK steering going in.....
All necessary reaming is done,
Durango box is in,
bars are set up and TRE's installed.
Steering Stabilizer bracket removed
Sway bar end link mounts removed.
I have mocked up the new tie rod and drag link in place, and it its evident that I need to relocate my track bar mount, and.... most likely..... modify my track bar.
So I think what will need to happen is that I'll need to cut / shorten / sleeve the track bar and fab up some sort of mount over the axle, as well as cap/brace the coil bucket on the passenger side a bit......
Thats what I'm going to need help with. I have had one offer so far...but I'm not sure scheduling is going to work out.....
I can/will kick down food/beer & cash for time and supplies if needed.....
I can cut/grind/prep/paint/etc... I just dont have the means/supplies to do this part of it all.
If any of you have the time/means and are willing to help me out, I'd like to try and get this taken care of tonight if at all possible.
I'm working today but should be back to my place (Gresham) about 5-5:30 or so....
The jeep is there and I still have a few things to finish up before it's driveable.
(bleed system, install cotter pins, grease zirks, and tighten all nuts is all)
Any takers? (thanks in advance)
Durango box is in,
