Ok, I don't know if FitchVa has trademarked any name for his relay box, but after seeing it, I decided to try and make my own. I chose to do a 6 relay box in a 4x6x2" project box. I wanted it to be modular, just like Fitch's, except I wanted to have all of my connections outside of the box, so I wouldn't have to run anything else inside.
Here's how it turned out:
Here's a closer look at the wiring:
LESSONS LEARNED:
1. No one knows what a Bosch style relay is anymore, and they are expensive in retail stores. Buy them online for <$2 ea
2. Buy connectors in bulk from somewhere other than Lowes, Advanced Auto, Walmart, Radio Shack, etc...they are expensive there
3. Measure twice, drill once. I would have rather had my input and output terminal wires coming from inside the box on top and the wires going to the battery and devices on the bottom. This would have made it easier to run the cabling and protect them from weather
4. Figure out a better layout for the terminals and Cat5e plug. They work, but the lines are going to be crossed once I hook everything up. I would have preffered to put the Cat5e jack (to switches) and 6 pos barrier (to lights & stuff) on the long side, and the two pos (to + & -) on the short side.
PARTS LIST:
Project Enclosure (4x6x2) 270-1806 (1)
Buss ATC fuse panel is BP/15600-06-20 (1)
Relays (6)
12awg Right angle terminal (12)
12awg ring terminal (9)
12awg female push on terminals (6)
18-20 awg female push on terminals (6)
Cat5e Jack (1)
Cat5e (1ft)
12awg wire black (dunno, didn't bother measuring)
12awg wire red (dunno, didn't bother measuring)
ATC fuses (6)
Single gange, single jack face plate cut down (1)
6 Position barrier strip 274-659 (1)
2 Position barrier strip 274-656 (1)
WRITE UP:
Here is the writeup I used from Fitch: http://fitchva.com/jeep/?p=47
I'm still working on adding something to protect the terminals better. I might add something that fits between the lid and the box and covers the terminals...I just haven't figured out what that something is yet.
LESSONS LEARNED:
PARTS LIST:
Relays (6)
Cat5e Jack (1)
Cat5e (1ft)
ATC fuses (6)
WRITE UP:
