Talyn
- Radford, Communistwealth of Virginia
I would really like to see this problem solved prior to the fan upgrade. While it is a worth while upgrade you should be able to fix it with your stock e-fan. You will be throwing another nut into the mix. Besides, you already have the timer and once it is installed you won't have to do anything to make it work with the ff dynamic fans. Also if you do get them I recommend you get the shrouds and mount them some other way than the nylon thru the radiator zip ties. Do a search on here for ff dynamics.. someone on here posted a good and easy way to not use the clips.
