muddeprived
- PA
Taking the relay out of the fan circuit isn't a great idea. It is always best to have as little load on a switch as possible. Let the relay do it's job of switching the current. If you want to be able to turn the fan on manually with a switch, wire it to the coil side of the fan relay. This way the fan will run when you want it to and also when the computer tells it to, the best of both worlds. Plus you retain the OE power circuit to the fan which is correctly wired and protected from the factory.
B
That's the normal switch setup that alot of people run but I need the delay timer rigged in there too so it stays on for a minute or two after shutdown, blowing as much hot air out of the bay as possible. By the way, what is the "coil side of the relay"? Is that a separate wire? (sorry, trying to learn this stuff)
Thanks for that info on the plugs. I ran champions since I bought it and then switched to NGK's cuz everyone said they help (like u said lol) and it was in the TSB but there's no change and it's still misfired like usual (come to think of it, maybe a little more than usual).....unless i leave the hood open lol. Is there a law that says I must have a hood on the rig to drive it? i'm about to take the damn thing off and toss it in the garbage for a simple 5 minute fix. :yelclap:
