joe_peters
- Grants Pass, OryGun
Has anyone with a late model XJ installed the Hood Vents?
Have they helped with the heat soak problem?
PM Muddeprived, he installed them with ZERO effect on the heat soak.
decided to just remove the aluminum heat shield located between the injectors and manifold Since removing the heat shield the injector vapor lock problem dissapeared.
You mean this heat shield ?
Has anyone with a late model XJ installed the Hood Vents? Have they helped with the heat soak problem?
I tried to leakdown test my fuel rail with this
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_FUEL-PRESSURE-TESTER-Actron_9030328-P_N3388_T|GRP2018____
The friggin tool leaked at the test port. I tightened it up with the pliars, which destroyed the o-ring inside the fitting. POS...
Guess I have been lucky with a cheap fuel pressure gauge from Harbor Freight.
http://www.harborfreight.com/fuel-injection-pump-tester-92699.html
. Maybe I'll get one. My problem is so intermittent, I'd like to leave one on full time and remote it to the cab. Dunno how safe that is...
any chance if any one knows what year they switched to the 2 cats right next to the block?
