- San Diego
unless you are 100% positive that the arms are adjusted so that there is no pre-load on the bushings, then yes. removing the springs is necessary.Are you saying I need to remove the springs, disconnect the sway bar and the shocks?
My only issue with this is:
1)I have no jack stands.
2)I really don't have the cash right now to purchase said jack stands. This school year has taken a toll on my savings.
3)If I do get jack stands, I doubt they will be tall enough to reach the frame, and I have nothing to place underneath them to safely get them to that height.
4)I don't have spring compressors. I guess I could rent them, so that would be easy to solve.
doing this job without jackstands is not a good idea, however as long as you have a jack, suitable substitutes are available.
all you really need is to:
1.jack up one side of the front axle so the tire on that side is off the ground,
2.support the frame with a jackstand, stump, etc
3.remove the tire, shock, sway bar and possibly the brake caliper and steering at the drag link.
4.then jack up the other side of the axle, support that side of the frame
5.remove tire, shock, sway bar, etc.
6.drop the axle out as far as it will go, this will allow you to remove the springs without the compressors.
7.then you can jack the axle back up to ride height to set your caster, and adjust your uppers.
Bottom line, I'm ill-equipped. I am in college and due to a lack of space, had to leave the majority of my things behind other than some hand tools.
if you can get your hands on a jack and some stands, thats all you will need to make this happen.
I certainly don't want to destroy the bushing and have to replace it again, but at this point, it looks like I may have to just try to bolt it back up as it is and hope that won't be the case. I only need about just under an inch, so I think it's just a case of fighting that weight as I'm pretty sure the arms were well aligned to begin with. If it does get destroyed quickly, I'll be home and working for the summer in about a month and will be better equipped to go at it then.
if you have to make it last a month, then so be it. but when you get home, come back to this thread and do it the way I told you and you won't have to worry about it.
