Gojeep said:I run my intake through cowl induction too and works really well for me.
Full write up on my site but of coarse you would need a cowl bonnet in the first place.
What the hell is that 55 gal. drum for?
Or is that a Weber?
xj-fx said:What the hell is that 55 gal. drum for?
Or is that a Weber?
Gojeep said:The water does not run in so long as you drill the hole as high as possible in the firewall to keep it above the floor of the cowl. This is how your vent system is working now too and it does not rain in on your feet because the opening is about a inch above the floor of the cowl. Just take it off and have a look and you will see what I mean.
At that time it would draw air from the drains with one at each end inside the guard.Littlewhitexj said:^^ Thats what turned me off to this idea. Too often in the winter my vents are covered with ice and snow which I think would lead to crappy performance.
Umm, clean your vents when you do your windshield?Littlewhitexj said:^^ Thats what turned me off to this idea. Too often in the winter my vents are covered with ice and snow which I think would lead to crappy performance.
jerics4life said:what about snow?
you think it would leak in?
always_eating_mud said:has anyone here taken thier airbox off and run a snork out, up, and then put a cone filter ontop and use some sort of water proffing, a buddy opf mien has it on his samuri like this and i was thinking of makeing mine this way
Mothertrucker said:how did ya'll mount your pvc snorkels to your a pillar??
They have a nut moulded into the snorkel itself. You just then bolt a bracket from that to the backside of your A piller. You can see it on my site as have a couple of write ups there about them. www.go.jeep-xj.infoMothertrucker said:how does the "real" $600 snorkels mount?
and i might use the straoping/screws method
Where did read the melting point is 413F? I read 173F on wikipedia.I did some quick looking. The melting point is 413.6*F, and the glass temp (from what I understand is it's starting to get soft temp) is 185*F. I have a modded oven thermometer to measure underhood temps, and the highest I have ever seen it (ofcoarse the ambent temp here rarly gets above the mid nintys) is 158*F, and when travaling down the road at any resonable speed the intake (measured on top of the filter) air is usully 5*F , or so higher than ambent.
