Markos
- Seattle, WA
Someone needs to come up with a telescopic snorkle...
JEONLYEP said:But I do have to ask about added noise inside from that set up
I thought about doing that 10 years ago and was going to carry a 1 meter extension to slip in-between the base, just above the cowl, and head for the deeper crossing only.87manche said:I had researched the marine vents and my idea was to go with the cowl induction, but with a mushroom on thop of the cowl. That way I don't have to run pipe up the a-pillar and if I ever get water up to the windshield I've got more problems than the intake.
We think a like.87manche said:that was my plan also. That way I could have it sitting ontop of the cowl for daily use, and have a 3 foot extension to take it over the roof for serious crossings. I could also take it off after the crossing so it didn't get ripped off by a tree. I'll probably make it so it's a friction fit with a lubed o-ring in there to seal it.
Kejtar said:For a filter can look for a rover canister. Then modify it slightly to take the stock rubber hose then take another rubber hose and come out the side into whatever you're going to use on the side. This is what I did. I used another long rubber hose (air intake) in the fender. IIRC it came of an older Ford or Chevy full size truck.
It was a range rover... I think 93ish ~ 94ish.Boostn said:Nice idea, what year and model rover did that air filter canister did it come from?
Couple more notes: when you look at the pics of the rover canister you'll notice that the diameter of the input and output is pretty narrow. I took those off, took a piece of 3" exhause tubing, tacked it on and then I used some marine poly putty to seal it up and reinforce it (you can use bondo). Sand it down, paint it and it looks like it's factory setup.Boostn said:Thanks!
