I'm personally doing the ABS conversion, and found this on a 1990 XJ same model as mine (even had the ABS) but the abs went bad and they did this mod to it.
You probably don't need the proportioning valve, but you need the booster, the master cylinder, I grabbed the proportioning valve, as it was attached to the same assembly (and needed it anyways). There's also a big vacuum tube that connects the booster to a hose fitting just above the EGR valve.
Also, you may need to dig around the yard quite a bit, a lot of the grand cherokees have ABS brakes on them, you can tell because there's a big ABS pump sitting right in front of the booster/MC assembly.
