- San Diego
The 95-96 dual diaphragm booster is a bolt in to the earlier rigs, just get the pedal with it. It even comes with an aluminum spacer plate to make the angle right, no stacking washers. Way less work than the WJ. Also all the XJ, ZJ, WJ had 1" bore master cylinders.
less work but then the washer bottle wont fit, correct? i need to get a new MC/booster ASAP and am on the fence about 95-96XJ combo or a WJ set up.
and also, with the WJ booster, someone addressed that the pushrod is at a somewhat severe angle at the brake pedal. any issues with this? is the only fix going to be cutting off and welding on the end of the pushrod from my 90?
