Garage Essentials?
EDIT2: ... safety glasses (and if you wear glasses, a face mask) are REQUIRED! My insurance company has paid at least 1500 dollars to the ER so far and the bills are still coming in... all due to a 0.1mm fleck of metal that found its way past my glasses on new year's day while I was using an angle grinder. It would be at least 6k out of my pocket if I didn't have insurance. Learn from my mistake on that one.
X2!! i wear safety glasses religously when doing metal working- anytime when drilling, grinding and welding. of course i wear a welding hood when welding but i also wear a face shield when grinding. even when taking those precautions its possible to get debris in your eyes. dont take chances with your eyes.
on that note, a small box of disposable foam ear plugs is a good tool to have as well. what did you say??
Agreed on that as well, forgot to mention it. The first time I spent most of a day using an angle grinder I didn't use ear plugs and couldn't hear anything for quite a while. The next time I did, it's an amazing difference...
BTW, if you have the same "I wear polycarb lens eyeglasses and it'll be fine, and safety glasses throw my glasses at a wacky angle" excuse as I used to, you can get a full face shield for like 3 bucks at Harbor Freight. No excuses... unless you like wheeling blind/with no depth perception?
assortment of cheater bars... absolutely required. I bought about half a dozen odd lengths from the bin next to the pipe cutter/threader in the pipe aisle at home depot. A 4 foot long piece of 2" black iron is GREAT with a large monkey wrench when you're putting a pinion nut on...
Really? I have a breaker bar that is about 30" long, I prefer that over a cheater bar. I like using the right tool for the right job...
Full torx set.
This really neat rechargeable LED work light that home depot has in the work light section in one of the electrical aisles - comes with an AC charger and a lighter plug charger, I keep one in each Jeep now because I'm tired of crappy chinese flea market flashlights dying on me.
Keep a random bald tire on a crappy rim around, great when you need to take the nut off a stub shaft + unit bearing and don't want to put the thing in the vice, I just thread a couple lugnuts onto the studs most of the way, sit on the tire, and crank away with my breaker bar and a cheater bar. Works every time.
An engine hoist or a sturdy hook in the ceiling and some rope + block/tackle are great. I use my engine hoist to lift things out of the back of the MJ when I'm too lazy to do it by hand now - great for unloading axles alone, etc.
An assortment of mallets and hammers is good too, I used to be the guy who only used a small carpenters hammer on everything, then I got a 6lb hand sledge (actually a blacksmith's hammer) and found out just how much easier it is to knock a unit bearing out with a hammer of the right size.
EDIT: oh yeah, the OEM brand pitman arm remover at AutoZone is great, well worth the $15 it costs. I use mine to pop the tie rod off the drag link without mushing up the crown nut or the TRE threads. A good gasket scraper (the kind that uses a straight razor blade) and a set of brass and steel punches are also required. Drill press is great to have, I use mine for way more than drilling, I made all stainless screws for the bezels on the front grille by taking panhead screws, putting them in my drill press, spinning it up and using a file till the heads were the same size as the rusty OEM fasteners.
I actually been thinking about getting a sledge. I had a really hard time knocking a wheel hub/bearing out of my other car with the 6 ouncer. Is 3lb good or would you prefer something heavier/lighter?
Safety glasses is another thing I need to get into a habit of. I started using them more when I changed over to glasses instead of the goggles. Fogs up waaaaayy less and doesn't facerape me. I'm using them anytime I feel shit is gonna go flying or if I'm on my back and shit will drop down.
All depends on how good an arm you have... or want to have :scottm: I've been having pretty good luck on hubs with my 4lb Stanley blacksmith hammer, but it kinda sucked popping a knuckle off a 30, I dented it pretty seriously. In general, I like to use the biggest hammer I can without losing controllability, because impact energy = mass * velocity squared, so you can get the same "oomph" out of a bigger hammer with less velocity.
add to all of the above at least one ABC fire extinguisher (at least one.....)
Jeff
Fire Extinguishers (more than one)
First Aid kit
Compressor & some air tools
2 angle grinders
Small welder
Sawzall
wrenches,sockets,screwdrivers,hammers,torque wrenches
6 or 8 jackstands
couple floor jacks
Engine hoist
Engine stand
Bench vises
automotive tools (vacuum gauge ,fuel pressure gauge,compression tester,etc.)
That's the cluttered half of the garage, in a separate room I have a 10x22 lathe, 5x12 lathe, drill press, grinder,small belt sander, measuring tools,etc. (these are for business and don't leave that room though.)
I've been very happy with an electric (corded) impact wrench, for the quick tire changes I don't want to air up the compressor for.
bags of rags are handy
an old beat up ghetto blaster, with a mish mash of speakers attached via various wires gathered over the years.
multi meters, a couple of them
a vernier caliper, & plenty of tape measures of various lengths
grease pencils, chalk, and coloured markers
and a Drill Dr, which has paid for itself over and over again, I bring it with me to buddies places if I know there will be some drilling going on.
Two of my favorites are my Dremel and soldering iron. Along with a soldering Iron you would want a good selection of connectors, shrink tube, wire cutters, a GOOD set of wire strippers, other misc electrical goodies and of course A Digital Multimeter is a must!
One of the ones with a CD player that you gotta smack the hell out of to get it to play? :D
one of those strap on LED headlamps. seriously. I thought they were ridiculous until i bought one. I only bought one because I was swapping a fuel pump that crapped out right after I filled the tank. I didn't want anything hot or electrical near me but needed light.
tools as mentioned, music and storage as well. if my stuff is disorganized while i work I can't concentrate.
x2
That reminds me. Welding gloves if you own a welder, and an old leather jacket. Steel toed boots are a must as well, I love em for hitting the JY and working on the Jeep because (a) I don't need to worry about dropping things on my toes as much and (b) if I get pissed and kick something, it doesn't hurt.
Several people have said air compressor, I say a BELT driven air compressor, if you can afford it. they are so much quieter than the oil free diaphram ones, if you switch from one to the other ,you will be amazed at how much quieter it is or pissed off at how much noiser it is.
The monkey wrench goes on the pinion and you can put the iron pipe against the control arm when its time to torque up the pinion nut. When I bench built my D30 I almost pulled a muscle trying to hold the bar and torque the nut at the same time.
A few dollys with 4 caster wheels make moving parts around and out of your way easily.
Assorted scrap metal, the place I buy steel from has a "bargain barn" where its all the cutoffs priced by the pound.
I have an old laptop hooked up to a cheap Staples speaker set with a sub that does a real nice job. Note: face the sub towards the wall, all those little things that happen to fly around a garage during a project seem to aim for that 5" soft spot.
Knowing how to properly use the heat from a torch and not damage what you're trying to replace.
A good dust mask or respirator depending on the job.
Oh yea, and a GOOD impact wrench and impact sockets. I just got a good deal on a snap on one that is rated at 800 ft/lbs on the max setting, axle nuts come right off.
A good water separator for the air line will keep all your tools working well for years to come.
In addition to the extinguisher on the wall, keep one handily mounted to the side of your welder cart.
I don't trust myself that much... it isn't mounted to the cart, it's sitting within arm's reach when I am doing things with a torch or welder :roflmao:
Another one I discovered today - assortment of dental picks of different shapes. Great for cleaning out and re-tensioning electrical contacts. The smallest flat blade screwdriver in a pocketknife works well in a pinch, but a dental pick is better.
a set of tip cleaners for a cutting torch works well for cleaning the female electrical contacts as well
oh yeah...
a roll of 1/4" vinyl aquarium tubing, I use that for a whole bunch of stuff. Great for bleeding brakes, a 6" piece of it jammed over the tip of a bottle of gear lube is great for filling up the diffs too, makes it so you can hold the bottle upside down between the gas tank and axle (or steering and axle) and actually get all the gear lube into the diff. I should get a hand pump one of these days but for now this works.
