- Rainy side of Washington
Pretty much.
After some searching it appears that power mode just feeds pin C11 on the TCU +12V. http://www.naxja.org/forum/showthread.php?t=60369
So all you have to do is check which wire goes to pin C11, and wire that one to the +12V ignition switched power to the TCU instead of the switch. Then you can use the switch for whatever you want that requires a +12V or ground to control... I'd probably rig it up with a relay as a manual override for the electric cooling fan.
