stroked88
- Carlsbad NM
dont know if they make a nut that has the thread of a screw. may want to just cut them off but leave a little stub
You got lucky and unlucky at the same time on those gears.
On one hand... they are the most common gearing in XJs, ever, bar none. Almost every 4.0L automatic XJ in history has them, aside from some of the ones with towing packages (and even some of them had 3.55s.) So you can get a replacement axle damn near anywhere if you booger yours up doing something stupid *cough* fun offroad, and be rolling by Monday.
On the other hand, finding deeper ratios in junkyards to get a cheap gear upgrade to make up for large tires is more difficult. You can compensate somewhat by swapping to a manual and keeping the 3.55s... but I don't know if you like driving manual transmission vehicles.
Also they have near zero resale value compared to axles with other deeper gearings but hey you got em for cheap, so that's no big deal. Don't expect to get more than junkyard rate plus a little if you ever sell them.
Glad this is going forward!
Great idea but a few problems... they're pretty tough to find in junkyards at least in the northeast, might be easier in PA. Also only 4cyl 5speeds came with 4.10s AFAIK, and some other engine/trans combinations from the early to mid 80s that are going to be heavily rusted and not in desireable axles anyways. 4.30 and 4.56 were also in a few (very rare) combinations, 4.30 was in the fuel economy package early on iirc and 4.56 only in auto 4cyls, which are not common at all and I can't even find part numbers for the 4.56 gearsets in the catalogs past the very early 90s so they won't be found in desireable axles either probably. All this gets thrown out the window if you find a really, really rare beast, an XJ that someone custom ordered with whatever gears they wanted, which you can't really predict by engine or trans, gotta look at the tags on the axles or preferably the stampings on the ring gears to be sure.Look for 4cylinder xjs at the jy and grab the axles out of it. They came stock with 4.10 gears, which will give you a fair compromise between performance and milage.
any news on the fiance's situation? or if your gonna have to sell
No no, check the FSM, the Power switch adds...like...100 HP...more than cupholders!
I did just get a new sunoco sticker. thats good for like 50hp and 3" of lift
But ya, mine has been flipped to power mode since 2005.
