souske
- The land of competition
Just throw the 35 back in and call it good
.005-.008 according to the dana manual.That pattern is not acceptable.
.005-.010 sounds like a tight tolerance. I thought it was more like .007-.012.
I'd pull out .002"
yea, no setup bearingsStill at .007 backlash? For an almost perfect setup. Pull .001 out of the pinion and tighten the backlash up .001-.002. Backlash is usually .005-.010 for 44's, depending on gear vendor.
Your probably not using setup carrier bearings.
What you have now is acceptable. The pattern is centered on the face (most important) of the tooth but not heel to toe (not great but works).
still a c hair too close, huh
.009", a little out of spec.
dowork, got your pm, thanks!
does this look like the pinion is too far away now?
im using specs from the dana manual, and i'm running a dana ring and pinion so it should be right. i dont feel comfortable going out of those specs, no offense.
