IH392
- Oakdale, CA
You are very close or right on. I would try to move it a hair deeper like .001-.002. Just for sh!ts and giggles and compare it to what you have now.
got none left, i'll have to try again in the morning.Spray the guts down with brake cleaner and get rid of the excess marking compound.
thanks, i'll see if i can shuffle some shims around and try that tomorrowYou are very close or right on. I would try to move it a hair deeper like .001-.002. Just for sh!ts and giggles and compare it to what you have now.
everyone agree on adding a thou or two after seeing those last pictures?
Not till you clean it up a bit and get a pattern to look at.
hmm i can try thatWhen I was learning this, someone suggested to me, to add some gear oil to the compound. I think I do half and half, and apply thinly as possible but still cover the whole gear face. give that a shot.
yea this stuff sucks. what do you apply it with, the acid brush that comes in the install kit? i'll try the oil in the morning.wow....lots of marking compound.
I mix it with a slight dab of gear oil and use about 1/20th the amount you have been using.
Are you turning the yolk to get the pattern or are you turning the ring gear?
i cleaned those spots and reapplied it for the last pics. what am i doing wrong?
the stuff is so thick it's hard to get coverage without putting a bit on there with that little acid brush
i tried turning both, but ended up turning the pinion while holding the ring gear pretty tight. seemed to be the best pattern i got vs holding the pinion and turning the gear. the rag didnt seem to hold it as tight as my hand could
