Coil spring issues.....
Ghost
Member Number 257
So when I was unloading I noticed this.
Passenger
Driver
I bent one 7.5" coil up in Harlan a couple years ago and contributed it to the side winch I did in Lions Den which also parted my TB from the frame rail in not a very neat manner...... With the suspension compressed on my trailer shouldn't both coils be more or less straight? Sense the chop and wheeling it I have been kicking around lowering it before the crawl. Maybe about 2" or so. So lets beat up on my jeep and discuss..... FWIW I want to eventually go to ORI or Coil-Overs up front.
Its the nature of having a flat bottom coil plate. You can try clocking the coils
The flat bottom makes it bend like that when compressed? That makes no sense because they are both the same. Only difference is one is turned on the plate in a different direction from the other.
Exactly. It's just twisted. Jack the body up and see if you can twist it to unbind it and it should be fine. It happens.
Interesting. I guess the solution would be a different base or a recess in the flat bottom ones?
Looking at the bottom right of the passenger coil it looks like the spring retainer is stuck at the open of the coil if that makes sense
You might be seeing where the last set I bent was tacked in place. I have been kicking around lowering the whole jeep again. Maybe a 5.5" coil and ACOS. Would need to redo the whole front winch bumper for that. I really want to go to ORI's at some point. That however is a whole new can of worms......
Did you figure this out? I'm still pretty sure the retainer plate is wedged in the spring
I have not had time to look at it too closely but from what I can tell it looks like a recess in the plate it sits on will fix it. Had to repair my rear front leaf spring mounts before I go to Durham Town this weekend and did a motor swap on the boys 98 xj. :banghead:
