Clayer
- Northern Colorado
I've been a long-time watcher, never had to post because I have been able to find the answers I'm looking for. Until now.
1993 XJ 4.0 4wd RHD 285k miles
When I take my tired girl on my mail route she runs great when the outside temperature is less than 90. But when the temp. gets above 90-ish, the fuel pump will get super loud after running her on the route for about 2 hours. She has left me stranded more than once because once the fuel pump starts to get loud, I have about 30 minutes left before she dies completely. Once cooled down, she fires right up like nothing ever happened.
Work that's been done:
3 fuel pumps in 9 months, two I installed (Delphi/Chinese), and one I had a shop do because I was thinking maybe it was me (Bosch).
2 fuel filters
Crank position sensor
Cam sensor
Plugs/wires/cap/rotor
Coil
PCM
replaced all rubber fuel lines in the back and used air to blow out the steel lines
Heat-shield on all lines up top
ECM
Fuel pressure regulator
Transmission
I'm sure there are other things, but I can't remember them all!
EVERY SINGLE mechanic I have brought it to, tells me that I need to replace the fuel pump AGAIN. I have done all of the work on this myself because these mechanics are not mechanics. They all seem to be parts changers.
The only difference I have found, so far, is when I changed out the fuel lines in the back. Before I did that, she would leave me stranded when the temp was about 70.
Please help - oh wise people of this awesome forum - I need a wizard or a witch to chase this ghost from my poor old lady!
2 fuel filters
Cam sensor
Coil
PCM
ECM
Transmission
