Ouch! ABS is more durable than PVC (can withstand more beating), but in compressive strength, PVC is "stronger" for one. Infact, the only thing that I see the PVC worse in mechanical properties as compared to the ABS is IMPACT. The spacers will not see IMPACT loading! PVC spacers will be in series with a SPRING. The forces that will be applied to the spacer will be minimal. Im confidant in this design. PVC also outwieghs ABS in environmental wear, such as exposure to oil, sunlight, etc.
OK... probably not going to be enough to convince you guys... but its more important to convince myself seeing as Im the guinea pig in this project, so I could use the self assurance here. With the end caps, and the tubing, wall thickness minimum will be .4inch. Surface area is 4.9 sq in. For the spacers to fail in compression loading, a load of 38,000lbs would be necessary. Don't believe me??
Stress=Force/Area - Compressive stress of 7,900 PSI. this is the LOWEST value I could find.
7,900psi=Force/4.9insq - 7,900psi x 4.9in sq = 38,000lbs
What about stress concentrations? What if the spring doesn't sit flat? Well, the isolator will be between the PVC and spring. This provides even distribution of pressure, AND reduces any impact loading that the spacer (probably won't) see. Spacer will sit flush to the unibody.
Other stresses applied? Bending? nope. Torsion? nope. Shear? nope. Only leaves Normal stress (aka. the compression). No tension.
If you guys think im missing something, make me aware. The whole thing is goofy, yes, and i'd laugh at people doing it to, but after the research, its actually pretty reasonable. Most of you apparently think this is a disaster in the making... prove me wrong. I have yet to take on the mod, so if there is something serious, i can be convinced out of it yet haha.
as always... im open to what you have to say. good or bad. Thanks for all your input!
