IllianaXJ
- Southwest IN
Finally got a day off, knocked a few things off the list.
Trailer lined up.
HoBoxes Done.
WJ LCAs Done.
Add a coil isolator to correct rake Done.
Still to do:
Swap winch solenoids DONE
Fix minor vacuum leak. DONE
Fix A/C - at the shop now getting a JY compressor, new expansion valve and charged.
Hood vents - DONE
E-fan override switch.
Put hitch back on. DONE
Check fluids/change oil. DONE
Go thru spares and tools.
If I have time:
Change axle ujoint that is starting to chirp.
Extended idle switch.
Figure out if stumble at idle at startup is bad aftermarket TPS or something else - Fixed itself.
CO2 tank mounted and new mirrors put on.
