whitneyj
- Mayville, WI
another thing to consider is the castor. . . did you end up welding the shims on the spring perches?
easy to install. not much fab. and it's cheap.call me stupid but why would you want to go from coils to leafs??? seems to me you are going backwards in offroad capabilaties ?? or not ?? cant spell !!
muddyrocks said:It looks like you have the skills to fab anything you want... maybe I missed it, but why didn't you go with a shackle reverse set-up? and full width shackles? these considerations, as long as everything else is tight , including ball joints, might help eliminate dw.
256offroad said:i would do a shackle reverse setup otherwise first rock ledge you approach will put your leafs/dshaft in a bind.
NOT.
have a look at yj's etc. i had zero issues with front driveshaft and so on.
a shackle reversal has LOTS of adverse affects, as have been discussed to death on yj forums. a good shackle setup up front can be a lot better for rock climbing, as well as saving the driveshaft from bottoming out into the t/case. with a reversal, the axle will actually back away from the rock you are trying to climb. up front the shackles will push into it. only place a reversal is a good idea is on road, as it allows the shackle to naturally arc rearwards. other than that 1 benefit, which is not a massive difference, there are no others. i have driven both setups, and wheel with people that have done it. find one that is honest and they will say it is not worth the aggrevation and work invloved to do a CORRECT shackle reversal. i speak purely from personal experience BTW.
you may want to do some serious reading and get some first hand experience before posting stuff like that up. i would however highly recommend some mountain offroad boomerang shackles. they will stop the springs from inverting in the few instances they will want to. happened to me 1 time, and i do some pretty extreme rock action.
martin
X2 on all you said, but be a little gentler. The kindness is why I prefer to those "other forums."eace: Some vehicles with really bad steering setups for onroad (like FJ40's) really benefit from SR's... this setup really wouldn't.
Nice job overall on the rig. Have you thought about a YJ type shackle and mount? It might be stiffer and more stable overall in a front setup.
