XGarfX
- North Jersey
Highway speeds I'm just under 3k, the 4.0 really likes the higher rpms. The engine doesn't struggle as much and its in its sweet spot, you can actually feel the engine "smooth" out at the higher RPM on the highway. Just yesterday I was loaded down with well over a few hundred pounds of gear, spare parts and tools pulling long hard grades all the time the xj would hold strong in OD. I used to always be in 3rd gear but now my xj actually can hold OD on most any hills without even struggling.
Have you ever broke shafts yet? If not I would just say grind out the stock 30 shafts for full circle snap rings and put some new spicer 760x u joints in there. 75% of the axle shaft breakages in the 30 I've seen on the trails are because of the half moon c-clips spitting out and allowing the caps to walk out, once the cap walks out the trunion of the u joint smacks the axle shaft yolk ears and destroys both the joint and the shaft. With snap ringed spicer 760s, locked, 4.88s and 33s on some pretty tough trails I have not had a shaft failure. On the trail yesterday 2 guys broke 30 shafts on 33s, both of them were running the stock half moon c-clips to hold the joints in.
