X2 I have a cracked windshield in the Black jeep and a good one in the RedSo anyone know how to remove and install a windshield
power seats are easy, run a ground wire and use one of your empty ports in your fuse panel
On the windshield idk I'd like to know though. On the window you need to pull the Jeep side of the harness at pick n pull and cut it off back to far enough that you can tap into the wiring, you will need to run at least one power and ground to the harness and probably two wire between the two doors so that you can operate both windows from the drivers door. If you get your jeep driving you could bring it up to my place and we could figure out all of your wiring.
Had a really good time, crazy fun... A guy a few rooms away died on the morning we hit dock. Next time we are flying... 20 hours of driving, kinda sucks. But I'm a cheap as. So we will see.Nick I know what you mean I have bad one on my rig and good one in this other rig lol now just need to figure out how to swap them out.
By the way how was your trip man?
Ok that sounds simple what size fuse they need though? I have never messed with powers seats but going to be changing all the interior out so I can be done with my blue and have some grey.
Now just need to find matching grey back seats.
When I wired mine in, I think I am just running a 20amp fuse maybe even a 10. Id have to go look.
So anyone know how to remove and install a windshield or how to hook up power seats and windows to a rig that doesn't have power windows or seat :wierd:
I will help you replace your winsheilds i can get the glass. Nick do not even bother trying to pull a used windshield it will break trying to take it out and if you do get lucky taking it out alot of times you will break it putting it in your other Jeep
I have the tool to cut a windshield out. I have cut several out with out breaking them and installed a few about 20 years ago. We could go to a pic and pull and take a few out to practice.
Dave
Windshield removal: Remove the trim pieces and thread a length of piano wire or a guitar string through the sealant then cut around the glass using the wire.
Installation: Clean all the old sealant away, then apply new sealant (tape types are easiest to use), set the glass in place and tap around the edge with a rubber mallet to seat it.
Helps to have a heat gun to soften the sealant and suction handles to handle the glass. It's a messy job and the glass is easy to break.
I have been told they settle or work harden them selves over the years of use. When I use to do it I would check the the build dates and only take the newest ones I could find.
Dave
I am unemployed and i would not let my family ride in a Jeep that had a faulty windshield installed its not worth risking you or someone you loves life.
They use urethane on new cars to keep the airbags from blowing the glass out on deployment. If you're depending on the windshield to keep you in the car in the event of an accident .. I don't know what to tell ya. If you hit something hard enough to eject a butyl sealed windshield you're probably meat anyway. Use the 3M tape and make sure the surfaces are clean.
"Butyl tape and polyurethane sealant--two alternative adhesive bonding techniques--provide approximately equal windshield retention in crashes." (1)
(1) http://www.nhtsa.gov/cars/rules/regrev/evaluate/806693.html
