whitneyj
- Mayville, WI
hmm. . . So I'm gathering that it doesn't sound worth it to relocate it up even with the rails?
did the same thing for my rear shocks, they work amazing, arcd them towards the inside so i could use my rough country 4.5 lift shocks.i assume you'll need to do the same, they travel pretty well\
gas tank build looks amazing brother, i dont see you having any problems with the way you've done that.
Secure you pluming and electrical going to the fuel tank.-I haven't secured it yet because I'm not sure how they'll be routed around the upper shock mounts. I'm pretty anal about wires and other really important things hanging in harms way after a transmission cooler line got in a losing battle with the serpentine belt. . .
I sure hope you are using a grommet where the lines enter the cab.-I'll snap a picture of how the lines are going up toward the tank. There's about a 2" gap between the floor and the skid.
Nice welds with the flux core.-thank you
Is your welding machine 220?-nope, just a 110V, 130amp Clarke. Works like a champ though, I've put coming up on 50 lbs. of flux through it and no issues yet. I just need to preheat the metal before I burn 1/4" and heavier stuff and give it a break every couple mins.
Could you give any pointers about removing the upper shock mount? How difficult was it to remove?-It's not that hard if you don't mind tearing your floor up a bit. I used a sawzall and 7" cut-off wheel to cut the majority of it away, then used a pry bar to get under it and separate it from the floor enough to get a set of vise grips onto it. I worked the vise grips side to side until the spot welds gave and made a 1/4" hole in the floor for me to fill. Otherwise you'll be sitting there with a grinder grinding all the spot welds off carefully and gently prying them apart. That shock mount provides quite a bit of support the floor back there. Hope that helps.
wow, thats alot how i did mine the first time before i cut the body off mine, looks great man, you did yours alot better with the fully welded lines, i soldered mine and used 20 gauge paintgrip galvy.
nice goin man.
get some muratic acid from home depot for 6 bucks, it will eat the zinc coating off that metal so you can weld the shit out of it, just like put it on a rag and use gloves and wipe the edges you want to weld.
it will also eat any rust you have, and then you can just rinse prime and paint them after that.
i use the acid as flux so i can solder and weld galvy for the roofing stuff we make at work.
or you can hit it with a sandpaper wheel, but really the acid works the best, and it's only 6 bucks for 2 gallons
