Man. . . it's been a while since I've done anything, but I did get a couple cool things done today.
I started installing the minispool yesterday and got it done today. I already had the rear axle out of the Jeep, so removing the 3rd member was quite a bit easier.
I started by removing the adjuster nut retainers and the adjuster nuts. I counted the number of rotations each adjuster used to come off with the idea that that's what I'd need to thread those back on and I'd be good. . . wrong. Lesson learned.
Then I removed the bearing caps and races being careful not to mix them up.
Then I took the carrier out. Just for peace of mind I marked everything before I took it off.
Then I removed the ring gear bolts and knocked that off and separated the two halves of the carrier.
As I took the spider gears off I made sure to retain the washer thingys from the two big gears, those get reused with the minispool.
Dropped in the minispool after cleaning everything up in there.
The spider gears used one long pin and two short pins to hold everything together. The minispool only used the long center pin, I though that was a little odd. I would think that all 4 holes would be utilized.
Then I put everything back together, tightening the ring gear bolts in a star pattern to pull everything together evenly. Then torqued the ring gear bolts to 70 ft.lbs.
I put the carrier in 3rd member, installed the bearing caps with the bolts hand tight, and then the adjusters. I ended up having to stop there and go buy some grease paint to run a couple patterns, I wasn't thinking I'd have to do that, but I should've been prepared for it anyhow. oops. I got everything finished today, but I'm trading axle housings with a guy a couple hours away. My 9" is 65.25 WMS, and his is 67.5", which will match my front better. While the rear is torn apart I'm going to start phase II, that and I found out Uwharrie doesn't open until April. So I've got some more time to play with. I need to order some more angle to plate the rear half of my Jeep before I either relocate my bastard packs or swap in the 63" Chevy's. I'm just not sold on the Chevy leaves. They're 14" longer eye to eye than my bastard pack, which when kicking the rear axle back 5", that really puts my shackle out there. I'd rather keep the shackle box location, just built with 1/4", to keep from dragging over everything. So we'll see what I get convinced of in another thread. . .
I've also got some UBE's a buddy's been building me at work. I'm not about to spend $20 per ubolt, when I get G8 bolts from work. Kind of a no brainer.
Since I don't have the angle steel for the rails, or my tubing for the cage, I decided to tackles the front tube fenders. I got a late start on them today, so I only got the driver's side tube done and the passenger side is bent up but needs to be burned in.
I just used 1/2 EMT conduit and a conduit bender. Nothing really fancy. I ended up cutting the top of the fender a little higher, otherwise I couldn't make the first two bends. I looked afterwards and decided to put one more bar from the middle of the main tube and tie that into the inner wheel well too. I'll be cutting up some stuff at work this week for the sheet metal to go over all of it and tie it into the fender itself. As it is now, I can grab it and move the whole Jeep with it. It's pretty rigid, so hopefully it'll hold up for a while. That's about all I got done today. Hopefully I'll get the passenger side done this week and get the angle I need to finish the rails this next weekend.
