nice work on the trim, very moderate, looks clean in that last pic.
hope your old lady is doing better.
are those the stock rear leaf springs?, they look nice and flat, bet it rides pretty smooth.
you oughta get a little bit longer main leaf so you can fix that shackle angle, you'll be glad you did, my betsy is flexin real nice now, cant believe how much of a difference the shackle angle made.
Thanks, I'm not all that excited about how well the rear chop turned out. If you look in the light you can see the metal buckled outward a little on both sides. I'm hoping to take care of that when I build the tube fenders.
I do have plans for the shackle angle, I almost scored a set of 63" chevy leaves with good bushings, hardware, and shackles for $50, but I was about 6 hours to late. Damn, huh? Oh well. I'm thinking about rebuilding the shackle box either flush with the frame, or slightly below it. I'd like to get a little lift out of it, so I can take a leaf or two out. I'm running two full leaf packs, all those springs make for a stiff ride.
I've been really slowing down on the build to take care of other more pressing issues, but I did manage to get a little done this weekend.
I had originally planned on making some sort of bracing to run from the belly pan to the tranny tunnel, but after spending a good while with a tape measure and some cardboard, I decided against it. Things were just turning too complicated for something I don't see causing to big of an issue. Instead, I cut out all the 1.25x1.25x0.25 angle that ran perpendicular to the vehicle and replaced it with some "homemade C channel". I took a section of 3x3x.25 tube and cut it in half, then welded it directly behind the tranny/tcase mount.
[/URL
Then I extended a couple of the previous reinforcements to tie into the "C" channel.
[URL="http://good-times.webshots.com/photo/2522117710103787292epckSO"]
I'm feeling pretty good about how it'll handle getting dropped on a rock. I put it back on the Jeep and used a jack in the center of it and it didn't move. I know it's not going to be the strongest thing in the world (close to the heavest at 107 lbs), but I feel it will be more than sufficient for what I'll throw at it. I've got some more plate steel that I'll be using to cover from the bellypan to the front spring hangers, that'll also tie into the bellypan, which should help the rigidity of it.
I didn't get much more than that done. I started to relocate my front brake hoses, but decided to wait until I get my new rightside caliper, so I only have to bleed the brakes once. I also got my front axle vent tube taken care of.
I just took 1/4" nylon air tube and ground the original vent fitting from the axle, heated it, and slid the tubing over it. I basically plastic welded it onto the fitting, but I'll be using a clamp as well for peace of mind's sake.
I also figured out another problem I was having. I couldn't get a snap ring onto the groove of the stub shaft. So when the wife got in the wreck and had to take my car, I ended up releying on the Jeep. The hubs ended up moving out just enough to sling grease everywhere. So just about everynight I ended up repacking the hubs with clean, fresh grease until I had time to figure out what was the deal. I took a spare set of shafts and compared the two. The ones from the 78 hpd44 had the groove about 5/16th" up the shaft, while the ones from the 76 hpd44 had them about an 1/8th". I swapped them out and the snap ring went right on. No more greasey messes, or repacking them nightly. Other than that, the front build is slowly winding down. Just need to build the front tube fenders, install the mini spools, finish with the brakes (to include a new MC from a 2500 dodge), build the trackbar and steering braces, drill and tap the steering box for hydro assist, look into a sway bar, and replace the front coil bucket "shims". Once the holidays are over I should be able to knock that all out in a couple weekends, then I'll start on installing the roll cage I'm picking up next weekend, and start to relocated the gas tank. Kind of indepth for my very first build huh?
