afd516
- Fort Worth, Tx
What would be the result if you had these lines backward? The rear of the valve cover to the air box and the front of the valve cover to the intake. I assume this is bad? Does this explain my oil loss through the exhaust? :dunce:George2 said:Ding. Old Man: 1, Others: 0.
The front port should draw air FROM your filter, no matter what kind it is. There should ALWAYS be a vaccuum FROM it, when the motor is running. The rear port should always be ATTACHED to a vacuum, like from a port on your intake manifold. Once you pull that line, then everything under the valve cover is under engine pressure. If both lines were pulled, then you should effectively feel a "poofing" as the crankcase pressure blows through both lines.
Back port to a good vaccuum, front port to a source of clean, filtered air.
What about a high volume oil pump? Would that have anything to do with blow by?
