- Port Orchard, WA
wildman said:Looks like you guys all have me by a few years, only 17 here, lol. holeshot, I'll check it that way, after I do what old_man said and clean everything out really good. thanks alot
Got FSM?
XJ_ranger said:Got FSM?
old_man said:Wrong.
How in the bleeding hell would leakage past the rings get into the exhaust?
Positive Crankcase pressure is caused by leakage past the piston rings from the combustion chamber (high pressure) to the crank case (low pressure), commonly called blow by. This pressure has to escape somewhere, that is why they put the crank case ventilation system, in the valve cover. If that vent gets plugged, the oil commonly gets forced up through the distributor shaft into the distributor. Too much blowby, even when the vent is open, forces minute particles of oil into the vent, over time, this small amount of oil collects in the hose and is blown into the air filter box.
Technically it is a PCV system. It is positive crankcase ventilation because the hose actually goes to a slightly lower pressure in the air filter. There is actually a vacuum being placed on the crank case. Just because there isn't a PCV valve does not mean it isn't positive crankcase ventilation. The valve got its name from the technique, not the other way around.
The piston rings have nothing to do with the valve cover
George2 said:Back port to a good vaccuum, front port to a source of clean, filtered air.
