RedHeep
NAXJA #1499
- Landenberg, PA
monkeyevil said:The bead looks good, but your heavy on the tube side, shift the weld a little higher up the edge of the housing there... I would do 3 stitches about that length spaced around the tube on both sides. Alternate from side to side.
MIG is just fine. Pre-heat and throw a welding blanket over it to cool slow if your anal about it.
All the tubes I (and JCR) have ever welded have been with a MIG. We have NEVER had a failure... not even a crack. On our own rigs, or on a customers. Back in the day I shaved my 8.8 (totally cut the bottom out) and welded the tubes (all with mig) with no metal prep but whisking the rust off. Wheeled it for YEARS with no problems.
Cast steel is very different than cast iron. :chef:
Thanks for the input, I'll try and adjust up higher.
