ddeadserious
- Detroit
So I've decided that rather than regear my 8.25 with my tax return money, I'm going to do an 8.8 swap.
Here are my reasons:
- I'm looking for an improvement in braking, and rear discs are my answer. But between all the hassle and money of doing the rear disc swap on the 8.25, I'm just going to get an 8.8 with discs already on it, requiring no disassembly.
- I need to regear, and can't afford to pay a shop to do it. So I've got my friend who will do it for me, but the less work he does, the more I feel I'm not taking advantage of him. But I've found an 8.8 with 4.10's already in it, and some used d30 4.10s for a nice price.
- My 8.25 was involved in a 60mph accident when it was in my last XJ, and I believe that's why I'm experiencing vibes at 55+ now, because I've ruled out driveline and tire vibes.
- I've got some rough country stainless braided brake line, does the 8.8 have a hole that this bolt for the brake line will thread into, or will I need to weld a nut of the correct thread onto the axle?
- What is YOUR experience with the whole proportioning valve thing? Will I need one or will it be fine as is?
- I can't disable my vehicle at any time(other than the time I'm ACTUALLY installing the axle) while I'm doing this swap. I'll be getting an angle finder, so I can get the pinion angle right. So I want to weld the perches on at school in my welding class(my home welder isn't strong enough to burn through the perches or tubes). So the plan is to have it ready , so it will bolt in in a matter of hours, so what I'm asking for, is measurements of the perches from center to center, and/or from inner/outer edge of the axle tube, to inner/outer edge of the perches. I can figure out the shock mounts on my own.
- The one I'm going to buy has an LSD, what are your thoughts on this? I know it'll be a downgrade from my 8.25 with the no-slip, but my wheeling:street driving ratio is about 1:60, so vibeless, good accelerating, good braking driving, is more important than trail traction at this time.(With the money from selling the 8.25 locker, I'll probably try to buy a locker for the 8.8 or turdy.) I guess I just don't really get the idea of a LSD, so please, explain how reliable it is in terms of really locking up the axle.
