I broke 2 out of 3 motor mount bolts on the drivers side of my engine last weekend wheelin.
I only had about an hour to work on this tonight, but it gave me enough time to get the motor mount bracket off, and the bolts extracted from the block. I still need to buy new bolts, and finesse the motor mount back into place.
Anyways, i started off with this:
Basically the rear bolt was the only one holding it in place, the bottom bolts head popped off, and the front bolt broke off flush.
So started off by supporting the engine and took the back bolt of the engine mount out. Then I took the main bolt that goes though the frame motor mount out. Dropped the bracket down.
Once that was out, the bottom bolt was able to come loose with a set of vice grips. Then i had to start drilling the front bolt. It was kind of a pain because i barely had enough room to give the center punch a few good whacks. I used a 90 degree drill attachment that i bought from harbor freight for $12, which worked out perfect! I used the same attachement to drill the inside holes for my TNT belly pan. So, I drilled the bolt, and then used an easy out. It came right out, luckily with no problems.
Heres the 90 degree attachment and broken bolts.
I will hopefully get new hardware tomorrow, and finish off the project. While im at it, i also have to fix a broken steering box bolt that i snapped trying to take the bolt out. So i will do a small write up on that too.
