Old May 15th, 2019, 10:58
FlyNNN's Avatar
FlyNNN FlyNNN is offline
Tire recomendations for stock Daily Driver?
I have a no-lift, daily driver 1990XJ that requires new rubber on stock 15" rims (235/70R/LR15). My present set is Good-Years Fortera which is no longer made. These are the best tires I have had on this XJ for what I do, which is strictly city/highway commute. Dry/wet surface handling are high priority attributes that I am after. I have discovered a few favorable notes on the Good-Year Adventure. Suggestions welcomed.
https://www.goodyear.ca/en-CA/tires/...rain-adventure
Old May 15th, 2019, 11:20
RCP Phx RCP Phx is offline
Re: Tire recomendations for stock Daily Driver?
Looks like a reasonable tread, what are the numbers on it?
Old May 15th, 2019, 14:01
FlyNNN's Avatar
Re: Tire recommendations for stock Daily Driver?
From what perspective? Trail, pavement? As mentioned in my original post, I'm only interested in a city/hwy tire. I hope the tread is not too aggressive for this use. The sidewalls look firm. Is every one only running 33" trail tires w/6" lift here? There has got to be some stock XJ's left out there.
The only numbers that I know are 235/70R/LR15. Are there any other I should be aware of?
Old May 15th, 2019, 14:30
PacificEd's Avatar
PacificEd PacificEd is offline
Our 1998 XJ runs the P235/75R15 Goodyear Wrangler Radial, which is kind of an AT just like what came on the YJ's and XJ's when they were new. They run good.
My 1994 XJ runs LT235/75R15 BF Goodrich AT KO2's and they are good too. They are more aggressive that what you probably need but they are wearing really well.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old May 15th, 2019, 15:24
nathanael nathanael is offline
If it's really just pavement, just put an all season on it like every other stock vehicle on the road. I doubt any modern tire is going to be the limiting factor for handling on the street.
Old May 15th, 2019, 18:17
Anak's Avatar
Anak Anak is offline
Stranger
Being located in Alberta, Canada I am going to surmise you need to cope with water in varying degrees of freezing. I am going to suggest you look at tires such the Falken Wildpeak AT3W and the Hankook Dynapro ATM.
I have been running the Falkens on my XJ for several years now and have been very happy with their performance (I am running a 30" tire on a daily driver XJ that sees occasional trail duty). I am happy enough with the Falkens that I have also put them on my Suburuban which is The Bride's daily driver.
I am running the Hankooks on my dually. They are comparable to the Falkens. I do not have as much time on these as the Falkens though. I do think they are worthy of consideration and comparison.
Note that we are in Idaho. Probably a bit milder weather than yours, but similar issues throughout the year.
Baby it's cold outside.
Old May 15th, 2019, 22:19
I'm talking about treadwear, traction, and temperature.
Old May 15th, 2019, 22:48
Ralph77 Ralph77 is offline
Seeing how my Jeep is just a DD I put some Cooper Discover HT's on her awhile back. An '00 with Ecco rims. 225 75 15. I like them. Not like I am testing their limits. Front end is tight and aligned. I keep them at about 34 lbs. Rotate yearly. Hating space saver spares I picked up an extra rim and purchased 5 of the tires. Spare is always part of the rotation. When I purchased them it was $532 out the door for the 5 using nitrogen instead of air. Got a $50 rebate and managed to get $80 for my old tires. I was OK with $80/per tire after the dust settled.
Old May 15th, 2019, 23:51
BTW, I don't see that tire listed in your size?
Old May 16th, 2019, 14:20
FlyNNN's Avatar
Found these;
60,000 mi./95,000 km Tread Life
Speed rating: T (190 kph)
Load index: 109 (1030 kg)
Product code: 758089572
Old May 16th, 2019, 14:25
FlyNNN's Avatar
On-line reviews seem to have many negative response on these.
Same kind of overall responses on the BF Goodrich's. I'll take a deeper dive into the KO2's.
Old May 16th, 2019, 14:29
FlyNNN's Avatar
More so basic rain during the warm seasons. Once water starts to freeze around here, I'll have my winter tires on by then.
I'll look into the Falken Wildpeak AT3W and the Hankook Dynapro ATM.
Old May 16th, 2019, 14:34
FlyNNN's Avatar
Originally Posted by Ralph77 View Post
Seeing how my Jeep is just a DD I put some Cooper Discover HT's on her awhile back. ... I was OK with $80/per tire after the dust settled.
I'll see what I can dig up on these Cooper's. Around here in Canada, I've got a feeling I'm going to be paying around $200 CAN / tire when I find something.
Old May 16th, 2019, 14:35
FlyNNN's Avatar
You are correct. I thought I did. No 75 either. No Adventure. Darn!
Old May 16th, 2019, 14:51
denverd1 denverd1 is offline
maybe a tire shop is better prepared to help?
Tire opinions for a daily driver in Colorado? SolarBell Colorado Chapter 23 November 28th, 2011 08:26
Daily Driver: Best Lift Height and Tire Size Combo for Weekend Fun Quills Modified Tech Discussion 8 May 14th, 2008 14:09
Good All Season Daily Driver Tire Recommendation? JoshRountree OEM Tech Discussion 43 December 25th, 2007 05:52
Tire recomendations... themangeraaad Modified Tech Discussion 33 April 19th, 2006 19:38
Tire size for a daily driver.....? Fogman Modified Tech Discussion 23 September 4th, 2003 20:30
