old_man
- Loveland, Colorado
I've never broken a u-joint where it didn't fubar the shaft.
maineiac said:i buy the cheep napa u joints ,i keep an extra one in the glove box. I would rather break a 10 dollar u joint than an axle shaft . but thats just me
There are plenty of people who will argue that both ways! to each his own!Jes said:How is a u-joint easy to fix on the trail?!
When a u-joint breaks it usually takes the shafts with it so why run a weak u-joint in a strong shaft?
It's pretty rare that a joint would fail without taking out the shafts. Even in the pic I posted above, the joint didn't fail, but the ears on the "good" side shaft are still screwed. They're bent bad enough that I couldn't get the cross out without a torch & those are Warns. I can't count how many joints I've seen fail & I can recall only a couple times where the shafts were still desent. You're much better off carrying full spares.Northern Pride said:There are plenty of people who will argue that both ways! to each his own!
I've had a couple of Detroits, and only had to rebuild one, but to my knowledge, none of them have spider gears, wouldn't be a Detroit Locker with them.Beezil said:I've broken the spider gears in my detroit twice now.....
I run 760x joints in stock D44 shafts. I just spit one cap out of a joint on the Rubicon and it bent the ears of the shafts enough to not get a new joint back in. I had a real nice fit with the caps in the shafts and put some high-strength loc-tite on it, and it still spit the cap first trip out. I have them tack-welded all the way around now.RobertF said:I've had a couple of Detroits, and only had to rebuild one, but to my knowledge, none of them have spider gears, wouldn't be a Detroit Locker with them.
Just needling you for a monentary slip, I'm sure you meant the coupler/drivers where damaged.
This happened to mine from the unloading shock of the axle/Ujoint breaking.
I'm sure a cheaper LunchBox locker can be taken out (shredded) even easier.
Bottom line, two or three replacement parts in my Detroit cost almost as much as a whole new unit. Is that worth saving a few $ on your shafts and joints if you know they aren't up to your requirements?
Jes said:I run stock shafts still and have never broken a u-joint(297 or otherwise) but have broken a fair amount of shafts.
Jes
Mark Hinkley said:Fair amount of shafts???
What in one day????
hinkley
Jes said:Oh give me a break(no pun intended )!
Four shafts in four years isn't a bad record considering how often I hit the rocks.
Jes
Beezil said:BTW, I wouldn't run another stock/760 set up WITHOUT welding the caps in place.
I believe this is a stronger set up to be sure.....
and since u-joints take out shafts, you'll never have to grind those welds!
