Which Posi Lok with RE 5.5 XD lift?
woodkrawler
Charlotte, NC
Im getting ready to order a posi lok set-up for my 90 XJ and was wondering if i need to get the 900 model or the longer 920 model. My XJ has the RE 5.5 XD lift on it. anybody have experience with either models with this lift combination? also can i use my current shift fork or do i need to upgrade to the one posi lok offers?? oh btw i tried searching an only limited results on the length issue.
lincoln
I bought a Dana steel shift fork for $15 bucks from the local Six States Dist. The stock alum units wear and there is too much deflection for the Posilock to function properly......trust me on this.
I'm running 6" with the 900 series unit...I wondered the same thing but couldn't find much data on how much longer the 920 kit cable was. Proper routing is key and I'm not a fan of the instructions recommended route of "under the steering shaft". If you don't have the airbox, you can actually route it around the front of the motor mount which keeps it away from the exhaust too.
One size fits all baby...and only cost me $0.10 worth of washers....
