- Torrance, CA
Brewfest should be motivation enough.
I'm still thinking, but it's going to be a 3 station single tier, aka Brutus 10 style. 6 feet long, stations on probably 24" centers, 2x2x0.120" T304 stainless, with 15" or 16" openings for burners, and mounted on 2"x6" wheels. Top surface to be probably 20-24" from the ground, with mountings for a couple of March pumps on the lower level. I'll probably get the basic sculpture welded together this summer, not sure when I'll be able to finish outfitting it. Oh, and 3 burners. I've got a Bayou Classic SG14 burner that seems to work quite well, much more efficient than the usual turkey fryer burner and rather controllable. One of my goals is to be able to hose this thing down with a pressure washer (yes, that means the March pumps will be removable,) besides, I just like stainless for this sort of thing.
At least initially, I'll continue to use my immersion chiller, but I'll have it set up to add a plate chiller (or a Phillzilla, etc.) at the drop of a hat.
I remember the good ol' days when you used to invite me over to brew :tear:
I do need to get off my ass and finish the gas plumbing and other misc details on the all-grain rig. Extract bores me, and with the local liquor store's specials of good beer for 10-14 bucks/case, there's little motivation to put in the effort.
While I think "wash down" is a notable design attribute in a 3 X 1/2 bbl system, you will undoubtedly spend more money (x3 or 4) than i think it's worth.
If you design and build process/work flow and ergonomics into your design, clean-up is not going to be an issue.
Once you get a few batches down, process will become habit. I simply don't make mess. I don't boil over, and I don't spill.
here's some pics from sunday....vienna style lager, double decoction.
What's brewing?
After the double helping of triple dipped ribs and 7 Belgian Whites?!?
A full bore, half roll, shit! That's what is brewing!
Hmmm..... something else I should consider. A Sankey keggle is only about 16 1/8" in diameter, narrower than I was thinking. If I build this thing with 15" open spacing above the burners, that won't leave much wiggle room for the keggle, and it'd only be supported by a few inches total at 4 points around the circumference. I guess I could always add a couple of cross members later if I ever go the keggle route.
Or, just drop the spacing over the burners down to 14" or less. Shoot, I could probably go all the way down to 12" and still have plenty of room for the burner & flame. I'd still leave the station spacing at 24" or more, there's no down side to keeping the stations apart.
Interesting shots of a single tier on NB's all grain board in the last couple of days got me thinking again last night and this morning. I might add 2"x0.25" bar in a diamond pattern inside of that. With 24" station spacing, and the tubing welded up on 16" square spacing, that gives around 12.7" square for the burner. That should be pretty easy to put together, and let me run pretty much anything from a 10 gallon kettle to over 30.
<chuckle> So I've heard. There are some uptight folks over there. There is the occasional bit of good information, though.
Denny Conn: "Sometime you just have to ask yourself, why isn't anybody else doing this?" in response to "Why not a wooden barrel mash tun?"
There's a can of worms.
Glass is heavy & slippery. It's fairly easy to clean, especially if you never, ever, ever let anything dry in it. If you drop it, it will shatter.
Plastic is light, but prone to scratches which are impossible to sanitize. Never reach into it with anything that's got a sharp edge or end. Even some bottle brushes will scratch it.
That kit is fermentation equipment only. You can make beer from extract with nothing more than a pot & a burner. For all grain brewing, you'll need a mash tun, something like a cooler or another kettle with a false bottom or drain screen.
<scratches head> You'd have to mash & boil outside the Mr. Beer, then just use it for fermentation.
Beezil will hate me for this. Go dig through the American Homebrewer's National Conference proceedings for Denny Conn's presentations. I know he did one in 2010, I was there. He does all grain on less than a shoe string budget, simple batch mashing in a cooler.
I forgot to say last time... I run primary fermentation in plastic buckets, and if I want secondary, in glass carboys. Clean them IMMEDIATELY after draining before anything dries on, and they almost rinse clean, definitely just wipe clean. The buckets never, ever see anything like a scrubby pad or a bottle brush, nothing more than a dish cloth.
